do you know if it is possible to switch the internal 2x GE & 2x SFP+ WAN ports to LAN mode? Or do I need to buy an FlexModule card where WAN/LAN is already mentioned?
Thank you.
Thank you.
According to the order information it might be possible but datasheet doesn’t say anything like that.
BPL-SDX-PRO-M2SDX Pro Base Model, No Expansion module, 500GB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN
BPL-SDX-PRO-M2-1TBSDX Pro Base Model, No Expansion module, 1TB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN
BPL-SDX-PRO-M2-2TBSDX Pro Base Model, No Expansion module, 2TB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN
Yes, it is possible. Flex module is recommended if you need more WAN/LAN ports.
Hi TK,
Please re conform that SFP Port in SDX can be used as LAN PORT ( base port not expansion ).
Yes it can.
