Hi Peplink Support,
I have created L2 Speed Fusion. What is the Maximum MTU size can carry over the Speed Fusion? i tested only can go up to 1500, even i have check the LAN setting Jumbo frame setting. The result still the same only can go up to 1500. Please advices.
Davis
Do you have more info for this ? Jumbo Frame over WAN link ? Mostly ISP doesn’t allow that.
do you plan to support Jumbo frames on SF connectivity between on-premises Balance router and AWS installed FusionHub?
Amazon seems to support Jumbo frames from late 2018 (Set network MTU for private virtual interfaces or transit virtual interfaces - AWS Direct Connect )
Best regards,
Gregor
Hello Sit , hope everything is fine on your side
Peplink support in it latest firmware build 8.4.0 build 5251 jumbo frame in speedfusion connection as i have tested in lab enviroment (setting up network card , and MTU WAN´s with a 9000 mtu)
But it seems that it not supporting it in layer 2 speefusion connection ? can you confirm this ?
thanks
