I have a Pepwave Max BR1 MK2. Current firmware 8.0.0
I have had no trouble running AT&T in SIM A slot but since moving countries and changing to a different SIM in slot B, twice now it has failed WAN Smartcheck and won’t reconnect. (The first time it reconnected after a number of hours for no reason at all)
Health check settings…
Method: Smartcheck
Timeout: 5secs
Interval: 5 secs
Health check retries: 5
Recovery retries: 5
Any advice would be great, thanks
we have this problem with one provider also, sometimes. My way to solve this issue; increase the Timeout to 10 sec. In some (slow) areas, I also change the method to ping or http.
Give it a try
Regards
Dennis
Thanks for the reply but unfortunately none of these suggestions got me connected
You have only one SIM installed, right?
Please disable the Healthcheck to test.
Hi Dennis,
Sorry for the delay in replying I haven’t had chance to try while disabling the health check- what does this actually do?
I still have not managed to get the SIM in slot B connected, I have only 1 SIM from this particular provider. However 2 days ago I tested the other SIM in SIM slot A (it’s complicated but I was just close enough to the other country) and it connects.
Nathan
I disabled Healthcheck and it connected instantly? Can you tell me if this is ok to continue to be disabled?!
Nathan
Yes that’s fine. You need it on multi-wan to identify failed connections. On a single active WAN it can just get in the way sometimes.
Thanks for taking the time to reply.
Ok then I will just leave it disabled
So the plot thickens, with Smart Check disabled it connects instantly- however it is not completely perfect. I have now realised that my 4x smart TV’s which are on a wired connection have no internet connection… for some reason the Pepwave does not like the network switch that they are plugged into, also I have a Harmony hub remote which connects through WiFi and that wouldn’t connect… as soon as I plug the basic Huawei back in everything works perfect…
Before the Peplink started failing the smart check and with the smart check on it worked perfect for a week and Netflix on all TV’s worked…
sorry, I was not on my computer
Disabling the Healthcheck means, that the router is not checking some parameters like speed, DNS and so on. So with only one SIM-Card it’s not problem.
For your TVs, you have to check the IP-Addresses. You can check the Client-List in the Peplink Status. Test it with a notebook…
Best wishes
Dennis
Hi Dennis,
Thanks for your reply, I got in touch with Peplink and they recommended I select the DNS health check and set the look up figures to 8.8.8.8 and 8.8.4.4 and it has worked fine ever since.
Thanks for your help
Nathan
