Does anyone know if there is a limit to the number of entries for the “WAN Connection Access Settings”, “Allowed Source IP Subnets” (Whitelist).
I can’t find anything in the documentation.
Cheers
Steve
Cheers
Steve
You should able to define up to 566 (Firmware version 7.1.0) IP subnets whitelist.
May i know your use case ? Did you really need to define so many “Allowed Source IP subnets” ?
Thanks for your reply.
No I don’t need that many entries, but I had no idea what the limit was.
I will have about 40 entries in my whitelist.
My use case is allowing global site monitoring of my sites around the world. I want to lock down the router access as much as possible, so I like to use whitelists. The site monitoring service has approximately 40 IP addresses that they use for monitoring.
Cheers
Steve
