Is it possible to use one or both of the WAN ports as LAN ports? I am using the SIM card as the source of the internet. I could really use one or both of the WAN ports for other LAN devices.
If it’s possible, how do I enable it?
Also, are any of the ports on the BPL-031-LTE-US-T capable of POE? I purchased a AP AC One Mini from Amazon and would like to know how to use PoE function? It doesn’t seem to power it when solely plugged in via ethernet.
Thank you. Since it’s marketed as a LTE router, seems like a reasonable request to use the SIM slot for the connection, and the WAN ports as LAN ports.
