This question is somewhat similar to Peplink | Pepwave - Forum
I have an 8 port POE switch which I’m using for my LAN side. It works great - I’m running 2 Peplink AP One Minis as well as some other PoE Devices on the LAN side.
I have a desire for PoE on one of my WAN ports.
I know of an easy way to solve it (buy a $30 PoE single port injector) but what’s the fun in that…?
Question: is there any way to use my single 8 Port POE switch and somehow have it work for my LAN and WAN connections at the same time.
Plugging the LAN and WAN into the same switch seems like a bad idea, but I wonder if there’s some way to make it work, perhaps using VLANs, or static routes?
In other words, something like this:
My POE switch is unmanaged.
