WAN and Cellular Conflict
We are designing a network, WAN and VPN are configured in the BR1 & SDX. In our testing, we are facing an issue that is: When the VPN tunnel and WAN are both connected the offloading of data through the WAN is not working well, But once the VPN is disabled manually the WAN (Offloading data to server) is working fine.
Now, what is the issue where we can fix it?
Can you provide a diagram of your network setup with the SDX and BR1 and a bit of insight into your configuration? Are you using SpeedFusion or another VPN protocol? Are these the only two devices involved?
We need to understand how you’ve set up your routing through / around your VPN tunnel in order to start to understand where the issue is.
