Does the Max HotSpot support VWAN?
Yes it should. It support fw 8.3 which has virtual wan baked in…
Can I get a perpetual VWAN license for this device? I believe the Hotspot is no a prime-care model.
I’m not sure any more.
See 5gstore here it doesn’t list the Hotspot but then it is a bit of a unique device…
Peplink 1x Virtual WAN Activation License
Lets ask @Zachary_Chow
Hi Omar,
The MAX HotSpot doesn’t support VWAN due to it’s older system specs. You can find a list of devices that do support it here.
If you’re looking for a more affordable option that can utilize VWAN, might I recommend the BR1 Mini or Balance 20X?
