Hi, I want to achieve VRF on my SDX Pro, but I couldn’t find this option or an option that could emulate VRF, I also try in a FusionHub but still no sucess. I found a post in the Knowledge base that says “Starting from Firmware 8, VRF is supported on FusionHub” but I don’t know if we are missing some license or a feature enablement in some menu. Hope someone can help me finding this option because is a MUST in the topology that we are designing.
Thank you for the community space to share our comments!
VRF is only available on Fusionhub.
Hi Martin,
Thank you for the previous guidance and for confirming that the FusionHub VRF functionality works as expected.
We have now successfully deployed FusionHub in our lab and validated that VRF correctly isolates routing domains and supports overlapping customer IP addressing , which is a key requirement for our platform.
However, as we move forward with a multi-tenant FWaaS architecture , we have encountered a limitation that we would like your input on.
- We are not able to steer VRF traffic to a downstream firewall
- VRF appears to only support forwarding traffic to another SpeedFusion profile
This prevents us from cleanly inserting a firewall behind FusionHub while maintaining VRF-based tenant separation.
Yes, this is the feedback I gave for the FH VRF functions a few years ago as well… the fusionhub needs the ability to:
- selectively include/exclude routes from the LAN interface (or dynamic routing protocols on that interface) into particular VRFs
- the ability to have VLAN or sub interfaces on the LAN included into a particular VRF
Yeah, for our case that can allow us to allocate different clients on the same VM, our workaround is having a different FH-VM per client. Also I think the SDX Pro must have the VRF features
