Hi Peplink Support,
What is the max MTU size that is supported on PepVPN and SpeedFusion VPN tunnels?
Hi Peplink Support,
Hi Peplink Support, can you provide an answer to this question.
May i know your requirements ?
Hi @sitloongs, the requirement is in regards to VPN Tunnels which are created by clients over the SpeedFusion tunnel which have for example a MTU size of 1500.
I still can’t get your concern. Do you facing problem for the application MTU size ? VPN on top of SpeedFusion ?
Hi, it was an question by a customer who had this problem with an other vendor. But it seems that with the SpeedFusion tunnel the problem does not exist.
