Hey all, I am trying to set up a policy-based (static route, IKEv1) IPSec VPN to an Azure network, however cannot get it connected. As I understand Azure does in fact support IKEv1, as long as you are not using dynamic routing. Can someone confirm the settings for this to work?
Also, do I need to add static route info under “Network > LAN > Static Route Settings”? Because I have the VPN all set up according to the Azure guidelines for a polcy-based VPN, however it is still not working. I am wondering if I need to add something under the static route settings.
Thanks!
