VPN does not work anymore after upgrade to the IOS 14. Any change could be make on the Peplink balance to fix it out ?
https://developer.apple.com/forums/thread/660499
Peplink 710 6.3.2 build 1723
Much appreciate for your help…
We tested with firmware version 8.1.1 and it is working fine.
Firmware version 6.3.2 is pretty old. You may upgrade to latest firmware version if you are using Balance 710 Hw3.
