VPN info
Please forgive my ignorance.
I understand the pepvpn is a peplink box to box I would like to add a VPN to my Pepwave Surf SOHO MK3 one like ProtonVPN so that all my connected PC’s / Cell phones on WiFi will use the ProtonVPN.
What is the best way to do this? including hardware like using a Raspberry Pi or loading new firmware.
Thank you
Hi troypulk1,
You can try to connect SOHO to ProtonVPN server by using OpenVPN WAN.
Please, check this post:
https://forum.peplink.com/t/how-to-get-protonvpn-working-with-openvpn-wan
Regards,
Rolandas
Thank you
