I installed 2 peplink balance 30 on 2 different sites with ipsec VPN configured correctly.
i just want to know the best way to configure this VPN connection in a high availability mode.
Currently i have 2 ISP on each pep.Is it correct to create multiple profile on each pep:
VPN between ISP1 on pep1 and ISP1 on pep2
VPN between ISP1 on pep1 and ISP2 on pep2
VPN between ISP2 on pep1 and ISP1 on pep2
VPN between ISP2 on pep1 and ISP2 on pep2
You can only create a single IPsec VPN profile between two Peplink devices. Our upcoming firmware will allow you to enter a FQDN for the remote gateway IP address however.
Currently 6.x firmware is still in beta at the moment and is still being tested however I have seen 6.x beta implemented in production environments without issue. You can get the beta firmware at the following link:
