I need advice with choosing a VPN. I have two Surf SOHO routers both running firmware 6.1.2 and I want to create a VPN connection between them. As I understand it, I can use either PepVPN or an IPSec VPN.
I do not need failover or bonding. Each location has just a single Internet connection.
I like the fact that PepVPN is only usable with Peplink hardware as this should make it more secure, assuming other security issues are equal. On the other hand, I am no expert in VPNs so the simplest to set up is also an issue.
Thank you in advance.
