Hi, we are installing Transits in a M2M application and we were wondering if those 5V 2A outputs are available ? Are these like the 5V connectors in several phones ?
Can you please specify the connector type and outputs.
Heriberto
Heriberto
Hi Heriberto, those are actually inputs so the device can be powered with portable battery packs. They are 5V inputs and the Transit requires a 2A input to operate correctly. You can hook up two packs and get many hours of continuous use. Thanks.
Thanks Tim ! It would be good to specify this in the specs for Transit, currently says: âDC 12V â 48V, 2Aâ. Thanks again for your time and prompt response, as allways.
