I want to use SpeedFusion to balance traffic across several satellite links. It is important that the satellite routers be able to see DSCP tags and identify each call individually. If the satellite routers can get that information from the data stream then they can prioritize and route traffic appropriately. In the absence of that information the satellite routers can’t prioritize VoIP traffic properly and Excessive jitter will occur Does SpeedFusion propagate DSCP tags from the LAN to the WAN links? Is there a way to identify how many VoIP flows/calls are in the Peplink tunnel?
