Hi guys
Does every Balance Series support Vlan Tagging ?
And does support SSL ?
Hi guys
Yes we support the above. Note that the Balance routers need to be on 6.1 firmware or higher to take advantage if VLAN tagging.
Jarid
Thanks for the fast reply.
Is there any roadmap implementation for balance appliance on virtual deployment ? Like Vmware, Hyper-V, etc
Actually there already is a virtual appliance - FusionHub. Essentially it is a virtual terminating end for SpeedFusion. Here is some more information as well: http://www.peplink.com/products/fusionhub/
Yes Jarid but it isnt a fully Balance appliance… Do you consider as a direct replacement ?
There currently is not a road map for a virtual load balancing appliance. Feel free to make a feature request here: Peplink | Pepwave - Forum
Ok I’ll do that Jarid thanks again.
Does balance support server load balancing ?
Hi Jmsoares91,
if you have inbound services built you can specify more than one server to handle the connections - here is an example off of the balancedemo.peplink.com
with this they are weighted the same so will handle equal amount of connections
thanks,
Taylor
Hello Mike
