Tangential follow-up to this issue with the 8.3.0b(X) releases.
Any time an Outbound policy change is applied, the VLAN WAN Health Check will fail, resulting in a disconnect on that VLAN connection. This failure occurs independent of changing the policy to include or exclude that VLAN WAN in the Outbound policy. The resolution is to move that VLAN WAN to ‘Disabled’, wait a few seconds, then re-add that VLAN WAN to a ‘Priority x’.
This issue is repeatable on a Pepwave MAX BR1 Pro 5G running 8.3.0RC2.
Has anyone else encountered this issue, or engineering confirm the same behavior?
TIA.
