I have a network with multiple VLANs, I wanted to setup a wireless bridge to a remote building with some access control. I would be nice to port tag (Access VLAN 100) the ports on an AP so that the devices connected to that port would be VLAN 100. At this time, all I see is LAN options (like a router) instead of a switch.
What AP model and firmware are you using?
Ap One Flex
Interesting,
My AP one 300 M and AP one Enterprise seem to support what you want.
Do you have a “Ethernet Port” menu on the left?
This is from a
AP One Enterprise HW2 3.6.1 build 1889
What firmware are you running?
I believe Peter is referring to the firmware 3.7.x and above. We have a plan to do the port-based VLAN. Thanks for your feature request.
is there an ETA on this? why is it on 3.6.1 but not 3.7.x?
I have 3.9.0 build 1067 AP FLEX ONE does not have this feature
Will this firmware come out soon?
We just put in an order for the new AP One rugged with 3x ethernet ports (release date in September). Going through the manual it does not cover info on VLAN port tagging but specs say full support for 802.1q. I assume an AP with multiple ethernet ports would also function as a managed switch, is this not true? Will firmware support this functionality upon release date or in future?
+1
Any update on adding VLAN port tag on AP’s with multiple ports? I opened a ticket last September about this (just after I purchased two AP One Ruggeds) Peplink said it’s in the pipeline. Is there an ETA?
Thanks!
Just bumping this, as I just did a deployment with an AP One Rugged and this still isn’t fixed (which is a bit of a joke tbh, as the issue was originally posted in Oct 2020 and its something old AP Ruggeds were able to do).
I could connect my laptop to the extra LAN ports on the AP One Rugged and set the VLAN on my laptop and everything was working as expected. I could even plug another AP One Rugged into one of the spare LAN ports and it trunked all the VLANs to the second AP One Rugged without issue. But I wasn’t able to set them as access ports for a phone/computer that didn’t support VLAN’s.
