I read that virtual SIM for remote provisioning the Peplink routers is or will be launched.
Who can tell me the status and maybe some product description on how this works?
This is available on the hd2dome with siminjector. The siminjector is populated with physical Sims and can connect to the hd2dome over ethernet
I believe these are the supported models at the moment (for the Sim Bank);
HD2 Dome
HD2 Mini (new hardware revision)
SpeedFusion Engine
HD2 IP67 LTEA ?
HD4 IP67 LTEA ?
Devices with ? are unconfirmed.
Please note that SIMBank is local i.e. SIMBank needs to be on same physical network at the router.
FusionSIM is still in development which is the product that will be used for remote provisions of SIM cards.
