Virtual routing forwarding
Does Pepwave routers support VRF (Virtual routing forwarding).
Hi David,
Currently, VRF is not supported in our product platforms.
Can you share more information on your application or usage that requires VRF?
Thanks and regards.
i will try to get more information , this is feature that one of our client ask.
VRF
Similar to MPLS or VRF lite multi-tenancy routing platforms. The ability to have different interfaces and network in different routing tables. True traffic isolation.
Does Pepwave routers support VRF (Virtual routing forwarding), now?
Thanks in advance.
No. VRF is not supported on any current models.
@MartinLangmaid Can we get vrf or route isolation added to the roadmap?
@Barranett, route isolation (Network > OSPF & RIPv2) is supported now.
Hi Team,
Not sure if this thred is old. But im looking for the same thing with VRF on the remote device.
Im trying to segment OT and IT networks and using VRF is the simplest way to do this.
Will there be support for VRF on devices such as Max BR2 Pro
Cheers,
Hi… @David_AB
Peplink Virtual appliance… have support for VRF
is there any plan for VRF on remote peplink devices?
Is there any development on this. Looking for this for my IT/OT sites so i can have dual VRF networking to seporate the networks via seporate Fusion Tunnels back to seporate Fusion Hubs or Seporate VRFs on the Hubs.
I would like to not have a seporate router doing IPSec tunnel to my FW or extra Peplink Device onsite to deal with the 2x networks
