I am trying to troubleshoot and issue where no matter the carrier my download is always great but the upload is terrible. Is there a way to see the levels on the main and aux antennas separately so I can see if my transmitting antenna is not working properly?
Hi! Welcome to the forum.
Which product are you using? The aux antenna was only used for reception in earlier models (LTE/CAT4), in later models (LTEA and up) both antennas are used for send and receive.
I would suggest just moving the aux antenna to the main connector to measure how successful it is.
Thanks!
It’s a max transit duo so it would be both antennas right?
I’ll give them a swap and see.
