Just started using a Peplink MAX BR1 Mini in my rv. Connected through T-Mobile and I have nothing but fail with all of my paid video streaming services. I’m not running any kind of VPN, nor any content blocking that I’m aware of. What do I need to do to get Disney / AppleTV / Prime video flowing through this router?
What plan with T-Mobile are you using? If it’s a business plan, there is a default business filter on those lines that can be removed with SE approval and a special SOC added to the line.
Do make sure you’re not doing any filtering or firewall content blocking on your BR1 as well, or using a VPN that could be blocked by those services. SpeedFusion is considered a VPN in this case as well.
You’ll want to contact TechnoRV. If you have verified you aren’t using SpeedFusion or another VPN (which a lot of streaming providers block), there is likely a block on the carrier side.
I use a dedicated streaming IP leased from torguard with a OVPN wan for my streaming devices, port forwarding works too! Oh how I wish i could have a second ovpn wan license to load balance these between my two ISPs. wink wink @peplink.
