I am trying to connect my Verizon 6620L device to the USB port on my Balance 380 to use in a test environment. However, I cannot get it to work at all. The 6620L works fine as a hotspot and Verizon has said it only needs to be plugged in to work. Any recommendations on how to get this to work?
If you mean U620L, this will be supported on the next GA firmware release.
Otherwise we have a special firmware available that supports U620L:
http://download.peplink.com/firmware/plb700/fw-b305_380_580_710_1350-6.2.2s003-build3365.bin
I have opened a ticket and I am having the same issue on the Balance 20 what is the firmware on the Verizon 6620L? Create a ticket for tracking.
Thx
Greg
Just received a firmware update on the Mifi yesterday. it’s not using 2.5
No, I mean a Verizon MiFi 6620L Verizon Jetpack MiFi 6620L | Verizon
You may download the following firmware:
http://download.peplink.com/firmware/plb700/fw-b305_380_580_710_1350-6.2.3s013-build3399.bin
If it is still not connecting, create a support ticket so we can go over more details and take a closer look.
-Likely due to MiFi firmware upgrade.
If you could provide your ticket number, I will take a closer look.
[Ticket #756835] Peplink Balance 20 USB stopped working after Verizon Novatel 6620L Manditory update 2.5 10/29/15
Ticket #756857
