Verizon Enterprise Network Extender over Peplink?
Hello - has anyone successfully installed a Verizon Enterprise Network Extender 3 over a Peplink router? The Verzion works fine over any other router but will not intiate an IPSEC tunnel outbound to Verizon when connected to Peplink. Tried directly out a WAN connection (various) and over a SpeedFusion tunnel. No luck.
Tim
We have a Verizon , Casa Systems Inc. - 4G LTE Network Extender 3 working behind a 380x.
We assigned a static ip 1-1 nat mapping for it.
Have you tried going under the Advanced → Service passthru → Enable IPsec NAT-T ?
Hi Jonathan. Thanks for the tips. I did try to IPSEC NAT-T service pass thru - no luck. I will try to the one to one nat. Can you share some of the specifics on how to set that up in the Peplink config? THanks again - I figured there had to be a way!
1-1 nat.
Confirm you have multiple ip’s / subnet on your wan.
Advanced tab → nat mappings.
Map public ip to private ip of device.
Set dhcp reservation so it doesn’t change
if you have multiple wans set enforced outbound policy at top of your list with source ip of the network extender.
If this doesn’t work, let me know and we can dive into it a bit when I’m back on Friday.
Ok thanks. That is what I figured you meant - no luck… Thanks for your help. If you have time when you return that would be great. THanks.
Send me an e-mail and let’s look at it tomorrow morning [email protected]
Please also invite my e-mail to your ic2 group as well so I can assist.
