When connecting the Verizon 6620 via USB…do you need to change the supplied address of 192.268.50.1 to something else?
I have read you do…or just plug it in and set it to one of the WAN ports?
If the IP assigned by USB modem is 192.168.50.x, you need to change the LAN other than this subnet. Else just plug and play.
How do I find the IP assigned by Verizon 6620
It is USB…
Just connect the Verizon 6620 USB to your PC than you should able to check the assigned IP address.
Thank You
