Hi There I’m using an AT&T Aircard 313U wireless modem with my balance 20 and I would like to know if there is a way to get some sort of verbose logging off the 313U device through the peplink. The modem is working fine, however we notice that it switches IP’s from time to time and this is causing problems with our network.
Other than up/down events there is not much else data available through the Peplink. It is very common for cellular IP’s to change quite often so you may want to consider getting a static IP from them.
