Salut, existe-t-il un moyen d’utiliser les ports LAN comme port WAN dans Peplink Balance 305.
MERCI
Yes if you can update your device fw to 8.4.1 you can then use virtual wan licences (these are bought separately) to add additional WANs to the B305.
thank you very much for your feedback, I had a doubt about the update Many thanks
