I have a Balance 30 Pro (home use) with 4 wifi connectors (generally use two with the paddles attached, and the two “remote” adapters that move the paddles a bit further away).
Just ended up with a Husky Parsec 7-1 antenna that supports 8x8 Mimo Wifi with a bit more gain than the paddle antennas (uses two WiFi connectors).
Wondering what the best use of the wifi connectors were. Do I just use the Parsec, or a combo of parsec and paddles, and whether it matters which connectors I attach things to.
Probably being too obsessive, because WiFi is pretty good throughout house with “boost” enabled (except for basement which is just okay) - but I suppose any improvement helps.
Geo
