Hi
We have a Balance SDX Pro where we have both our offices connected via Speed Fusion i Layer 2 mode.
Behind the SDX we have a Fusion hub installed for demo on a seperate VLAN.
There is a 1:1 Nat made for the FH, and it is off course not the Interface IP for the SDX used. It is a free IP
Firerull has been set up also.
Issue here is… The Speedfusion traffic does not end at the FH…
I can see it going to SDX local service?
Do I then try to create a socket on same Port with a tool. The traffic hits the FH.
is not possible to pass through SF traffic via 1:1 NAT to other WAN IPs`?
