Hi Everyone,
I am just attempting to utilize efficiently SpeedFusion Cloud.
Currently I have a MBX with 4 Cellular modules in use, connecting to a SpeedFusion Cloud Location.
Created 3 tunnels:
1 - Default (always created): current use will be for day to day browsing and downloads.
2 - WAN Smoothing: used for VOIP applications.
3 - FEC: used for Streaming.
As you can see in the picture, the Algorithm is VPN: SFC-MAD (2 WAN SMoothing), and the Destination is SpeedFusion Cloud SFC-MAD (1 - Default)
While attempting to use this rule, I saw no traffic flowing through tunnel 2. Everything went through the Default tunnel.
Streaming FEC, when activated, Netflix doesn’t connect. Attempted Priority and Enforced, but both seem to “block” Netflix connection.
I’ve gone through the config for a while and I can’t seem to understand why it’s blocking Netflix when I am forwarding it through FEC.
On the SpeedFusion Cloud, I normally use the Default tunnel to route any other traffic. But I found out that using the WAN smoothing tunnel gives me better bandwidth and latency.
SpeedFusion Default Tunnel 1:
SpeedFusion WAN SMoothing
Rules 1 and 2 are disabled as I am working on a live network.
Could anyone explain why this is happening?
Thank you in advance ![]()
