Hi All,
I am trying to figure out the best way to use 1 PEPXIM SIM injector to connect two HD2 Dome antennas and Balance’s WAN port #2 and WAN Port #3. I’ll be using the Balance’s WAN Port 1 to another higher-speed ISP. I tried a couple of different setups, e.g., using two of the SIM Injector ports (1 for each Dome) and HD2 Domes allocated to a respective SIM in the SIM Injector. I used the remaining 2 ports from the SIM Injector to the WAN ports on the Balance 380. I can load and use the SIMs with each HD2 Dome separately, but they will stop accessing the SIMs when I connect to the Balance 380. I can connect all 3 WANs within the balance, but the HD2 Dome assigned WANs will stop loading (stop blinking) the SIMs in the SIM Injector.
I tried a different setup where the HD2 Domes are connected to the SIM injector and the Balance WAN ports, but no avail. Does anyone have a successful experience with two HD2 domes and a SIM injector? Is there another better way to use them and connect to the Balance 380? Let me know what you guys think.
Thank you,
