Hi there, as you know I can only load balance between physical ports in my switch but what I want to learn more is using 15 WANs on this device. Is it possible to get all ISP connections into switch, then by using Trunk Port & VLAN can I connect more than one WAN connection on single physical ethernet port?
Hello Yigit_Konur,
For that many WANs you may want to look at getting a Balance 2500 (BPL-2500).
