Hi, there is some way to use lan ports as wan port in Peplink Balance 20?
Sorry, no this is not possible. If you need more WAN ports I suggest a Balance One plus the license key to change LAN1-3 into WAN ports for a total of 5.
Thank you Tim, I have a Balance 20 with two wan connected but I want to add a third wan, both wans and the third are ADSL.
Does your Balance 20 have the optional third WAN port on the front?
It is not possible to add a third WAN port to your Balance 20.
What happen if I use a USB - LAN converter to use the usb as a ethernet?
USB to Ethernet adapters are not supported on the Balance 20.
Ok, thank you for the support.
