I noticed an “In Control” App on the Apple store and was hoping I could use that to control my Peplink MAX BR1 Pro 5G Mobile Router. When I try to log in, I put the serial number of the Router as my “Peplink ID” and my password I use to access the In Control web interface and it will not connect. Is it possible to do? I was thinking it would be convenient to (say) enable campground WiFi rather than using Starlink or Cellular when it might work. Thanks Keith
Is the serial number the username you use to login to incontrol2 on the web?
Thank you Andrew. I use my email address to sign in to Incontrol2 on the web.
Then use that, the app is just using Incontrol2 APIs to perform the same actions you can make through the website.
