Hello Team members and fellow users of the device API !
I’m facing an issue on which I spend pretty much time on it… I’m trying actually from my local (exemple: 192.168.50.17:5000) to login into the api by using the following adresse : “https://{ip adresss of my router }/api/login?username=${values.username}&password=${values.password}”
It works, it returns a 200 status, but the fact is that the auth token is return in a cookie, and the setCookie can’t be done because the response header have the attribute SameSite=Lax.
So I’m kinda stuck at this point, any help could be great,
Hey @Jonathan_Pitts ! Thanks for the response you gave again, but this is not what I’m seeking.
But I appreciate the help you gave me, with your answer.
If I need to explain what I’m trying to do : I actually have a login form on my localhost address(which is this one : https://ip of my mac given by the router**:port of the router**/ which enable me to send the following POST request : https://id of my router/api/login?username=username value&password=password value
I’m using fetch, on a React environment, I recieve a 200 response, but there is a Set-Cookie header in the response can’t be done cause I have in this Set-Cookie the attribute SameSite=Lax.
I did some research and it appears that I can’t retrive the cookie containing my bAuth string until my localhost address isn’t the same of my router.
