Anyone with any experience using a WAN optimization ( Data-dedupe, compression, token substitution, packet aggregation, tcp window sizing, tcp spoofing etc.) type product (Riverbed, SilverPeak etc.) with Peplink? My concern here would be that most wan optimization products use TCP option bits to keep their data streams together - if the option bits are stripped … they lose functionality.
Hi Wanopt,
I have a client that is running Riverbeds behind each Peplink that are connected through SpeedFusion (Peplink/Pepwave proprietary VPN). This is causing no issues for him and should not be a problem for you.
Mike
Mike - Thanks - I appreciate the response.
Wanopt, No problem. Please feel free to reach out to me directly to discuss in more detail.
Take care,
Mike
That’s fantastic news! I used to be a big fan of Riverbed. It truly makes a significant difference in remote locations with limited connections. The SFC just needs to encapsulate the data entirely, including all the marked packets, and then release them on the other side.
What do the WanOpt devices see as their public IP address, the SFC public side?
