Using a POE Injector for Starlink
I have the Max BR1 Pro 5G that I’m using cellular and starlink with. I’d like to get rid of my starlinjk router and power block. I purchased the Yaosheng POE injector based on others recomendations. It requires 48V DC input and I only have 120 AC current in the area. I realise I can purchase a transformer, but I’m looking to see if anyone has a recommendation on a good quality POE injector that runs on 120V. I also Would like to get some guidance on what patch cables to use. The Yaoshing says it requires a T-568B pinout. Is this a standrads cable? Is the same cable used to connect from POE to DIshy and it is from POW to Peplink. Advice for this newbie is much appreciated. :wink:
What starlink dish model is it?
It’s a Generation 3 Standard
give this a try, should work for you.
Thank you!. I’ll order that. Do you have a recommended pacth Cable? Do i just use the one that came with the Starlink Dish?
So do you have the factory cable with factory ends on it?
If you’re looking for alternatives, any high-quality Ethernet cable that meets the Cat 5e or Cat 6 standards should work just fine.
Yes. Thank you Daniel. It’s all working fine. The POE injector you recommended is great.
I have the same router and a similar need for POE injector but for the starlink mini. I am using the poe splitter/combiner from mobile must haves but need a POE injector with a 120v as the OP. Any suggestions for the mini?
Sorry just saw this, you ever get this figured out, if not let me know I can send a recommendation.
