is it possible to use GRE tunnel within OSPF dynamic routing?
Best regards,
Gregor
Best regards,
Gregor
This should be a feature request.
Can you share the used case? In fact, this can be achieved if you are using SpeedFusion tunnel.
typical use case would be soft-migration from Cisco/Juniper type of existing networks (GRE+IPSec+OSPF).
Best regards.
Gregor
Do you mean you wish to migrate from Cisco DMVPN to Peplink solution?
