Hi Peplink,
SDX Pro has 2x USB WAN Ports.
Can customer use external 4G/5G modems connected to these ports?
Regards,
Deni
Hi Peplink,
Regards,
Deni
Hi @Rokas_Musteikis , thanks for your information.
I see all of the modems listed are mainly 3G/4G.
Do you have any reference for 5G modem?
Regards,
Deni
@deni.widianto only listed USB modems are currently supported. Why FlexModule was not considered for SDX pro ? There are LTE/5G FlexModules available for it.
Do the 5G FlexModules have all the allocated frequencies from the TV UHF Auction completed about 2 months ago and critical for ATT and Verizon higher speeds destined to be rolled out by EOY?
