Hi, My USB WAN Modem randomly freezes and needs to be power-cycled or unplug and plug USB modem back into pep20 or SOHO (same behavior across 20+ sites) which is hard for remote site.
Using: USB Modem AirCArd U313 ATT across all remote locations. In some of them using External antennas to get signal @ stable high level.
Question is: Is it possible to make USB reset via CLI or watchdog in the GUI. Signal level is not the case. Physically remove and plug USB modem back helps re-initialize modem and reconnect.
via CLI I getting this:
> system modem reset
sh: unbind: unknown operand
Usage: ./cli
./cli bandwidth.transferred
./cli bandwidth.aggregated
./cli bandwidth.wan
./cli status.clientlist
./cli status.cpuload -p NUM]
./cli status.ha
./cli status.s2svpn
./cli status.session
./cli status.wan -i CONNECTION_ID]
./cli system.debugmode
./cli system.eventlog -d] -n NUM]
./cli system.info
./cli system.reboot -y] -d NUM]
./cli system.restore
./cli system.uptime
./cli modem.reset
