I’m interested into a load balancing solution for an hotel (about 60room).
Which is the best solution? We have to manage two wan and one lte connection.
Usb modem port is for backup only or it could be used to do load balancing togheter with wan connection?
Sure, you can always enable it as an active connection. You can setup the Bandwidth Allowance monitor and select to disable the LTE connection when it hits your cap.
The Balance One is more powerful so I recommend going with that one.
