Is it possible use iPhone on Max on the go?
My customer would like to share the iPhone internet using USB connection. The Max identified the usb connection but the wan interface stayed down.
Thanks.
Thanks.
No you can’t usb tether an iPhone to a Peplink device. You can however usb tether an android smartphone, or you can use WiFI as Wan on the MOTG and set up either iPhone or Android device as a WiFi hotspot and share the internet connection wirelessly.
Thanks Martin.
Are there details on details on setting up using WiFI as Wan on the MOTG (unsure of what acronym means) and setting up an iPhone as a WiFi hotspot anywhere?
