Each feature could be leaking sensitive information, so their status should be a bit more obvious. Maybe on the dashboard, maybe on the Status tab.
On a related note, each feature is currently (fw8.0.2) devoid of status indicators, other than their main on/off checkbox. There is no way to tell, from the web interface, whether the target machine is currently reachable (ping), whether the requested logs are actually being received (impossible to tell?), is it using TCP or UDP for sending the logs, is it using TLS/SSL for sending the logs, how many log records have been sent, how many are sent every hour, etc. etc. Exactly which status indicators to show is debatable but showing nothing seems insufficient.
Thank you.
