What do I set the Upload Bandwidth and Download Bandwidth too? Also is this Bytes or Bits?
ie my DSL is 5 MBits/s do I set it at 512 KBytes or 5MBits?
Hello Michael,
You would want to set the up and download to the actual speeds as given to you by your ISP. The Balance does use this in a variety of functions so you do want to make sure that you accurately define these speeds.
As to how to enter it, you have the option for MB or KB, you can use either (again just making sure to put in accurate information).
I do hope this helps to clarify, please let us know if you have other questions at all.
Best Regards,
Jason
The Peplink Team
Is this MBytes or MBits?
Hi Michael,
This is rated in MBits per second or KBits per second for the other choice.
Best Regards,
Jason
The Peplink Team
