Hello Peplink/Pepwave Teams,
From our experience currently only some of the Peplink/Pepwave range allows for the full customisation of the LAN port from the default of TRUNK all VLANs. It would be very useful to see the ability to have Customised Trunk & Access assignments of the VLANs to the individual ports across the entire range and for these options to be uniform across all models.
Take these example from Firmware 7.1.1 comparing the LAN assignment options as seen in these images.
Pepwave MAX BR1 MK2 LTEA (MAX-BR1-MK2-LTEA-P) Hardware Revision 2 FW7.1.1
Note the missing customisation options for the drop down when port mode is Trunk.
Pepwave MAX HD2 LTE (MAX-HD2-LTEA-P) Hardware Revision 5
Pepwave MAX Transit LTEA (MAX-TST-LTEA-P) Hardware Revision 2
Note (though not shown) is missing the same customisation options as the BR1 Mk2 above.
Peplink Balance One Core (BPL-ONE-CORE) Hardware Revision 1
Peplink Balance 30 LTEA (BPL-031-LTEA-P) Hardware Revision 3
Peplink Balance 210 (BPL-210) Hardware Revision 4 FW7.1.1
Note the missing customisation options for the VLANs on the ports.
Peplink Balance 380 (BPL-380) Hardware Revision 6
Note the missing customisation options for the VLANs on the ports same as Balance 210 above.
Peplink MediaFast 500 (MFA-500-B) Hardware Revision 2
Please have added into future firmware to allow these options across the entire Peplink/Pepwave range. This can be particularly useful where there is a spare port on a router that can then be used for support or allow controlled access to a specific client required VLAN. When working with clients remotely we have occasions when we need a port on a specific VLAN to use for diagnostics.
This feature request is in response ticket ##786920 (being action by @Erik_deBie) and also to previous discussions here in the forum.
Posted by @Ron_Case in November 2017
Posted by @sitloongs in August 2018
We also look forward to thoughts around our fellow forum colleagues around this.
Happy to Help,
Marcus ![]()
