Unexpected routing via SpeedFusion
Occasionally I’m seeing traffic routed via a different Speedfusion node, when I’m not expecting it. I’m expecting it to be routed out via the WAN port.
Question is how would you debug this if I see it again.
I only noticed as a particular site geoblocked the exit Speedfusion node, and another sent a suspicious login notification about the exit IP address.
The strange routing went back to normal, when the client machine associated with a different SSID.
