I recently purchased a Balance One (6.1.1 firmware) and I am trying to understand some of the available options.
If I have some security cameras that I wanted to move to a VLAN (192.168.2.x) will those cameras be reachable/viewable from the 192.168.1.x network if I enable the VLAN trunking option on the Balance One LAN interface?
If so, do those endpoints need to be directly connected to the Balance One or can they run through a switch?
Camera (192.168.2.5) —|[INDENT=4]Switch (unmanaged)------- Balance One (Primary LAN IP 192.168.1.1 + trunking enabled as VLAN 2 w/ ip 192.168.2.1)[/INDENT]
PC (192.168.1.5) —|
How about if it is a wi-fi client like an iphone/laptop associated to an SSID that is tied up to VLAN (192.168.2.x) as mentioned above, will those clients be reachable from 192.168.1.x???
Correct me if I am wrong but I think they will reachable as by default, Peplink has inter-VLAN communication enabled internally. If you want to limit this communication between VLANs, you may accomplish it at the outbound firewall.
