Not a network engineer here, but am fairly knowledgeable but am unfamiliar with how the router config works. See attached pictures for the following question.
- In this configuration, are all connections working together as in a balanced bonded (all sharing the load) connection? When I look at Status/Real-Time reporting, it seems like the load is not balanced across all connections and usually I find that the cellular connections seem to always carry more of the load when I would think it all would be equal?
In this configuration, it doesn’t seem like the priority 2 connections ever get used, is that what standby means? I thought priority 2 meant, if priority 1 connections fail then priority 2 connections would be used followed by priority 3, etc.
In this configuration are both cellular sims equal priority? how does the router perform when both sims are priority 1? Can they both really be the same priority?
I could not find any documentation on how the router uses these priority levels and what it actually means.
